Adding Fog Lights
Adding Fog Lights
I am adding fog lights to my truck. I would like to hook them up to the factory switch so I can just pull it to turn them on. Otherwise I want to hook them up to the parking lights. Does anyone know which color wire it for the parking light power and the color wire for the headlamp power?
If anyonw has hooked them up to the factory"pull" switch let me know how you did that.
look closely
you need to check & see if you have the harness hidden behind the bumper first. if not, then you will have to make one or buy one. unless its cheap, i'd make it, its very simple. you will need a new headlight switch with the foglight option, even though your **** MAY pull out, it wont work, there are no internal pins for fogs. the yellow wire is to send power to the fogs, the white/black wire is for the fog icon. have you done a search for "adding foglights"? if not, do so. all the info you need should be there, if not , email me and i will send you a pic of the 99' fog schematic.( still tryin to figure out how to post a pic!) i am NOT an electrical guru, i just got mine to work after having ALOT of trouble figuring out my wiring problems with adding fogs to my expy, so its still fresh in the ol' noodle!
When i was in highschool me an a few of my friends just use on of those cheap test light to find the hot wire when we wired our fog lights like your going to do. All it needs is a ground and and you just stick it in to the wire and if the light in it comes on then we know it was the hot wire as long as you have you hi-beams on. hope this is some help.
