Sylvania Silver Star Halogen Headlights
Darren,
There are multitudes of Silverstar users on this board and I have yet to really hear a solid complaint chirped about them.
I'm currently running them in my fog lights (not in my heads because I went to a HID (High Intensity Discharge) system) and I love them!!!
They're more than worth the price.
Installation is VERY simple and is highlighted in your user's manual that came with your truck. I don't think you can go wrong with Sylvania Silverstars!
RP
RP
Originally posted by FlaresideGuy
You mentioned above that you didn't use the SilverStars in your Headlights - was wondering what alternatives you might recommend as I figure that once I replace the fogs, I am going to want to replace the headlights with something brighter, too!
John
John
Well... as an alternative to Silverstar bulbs in my headligts, I installed Sylvania Xenarcs. They are a true High Intensity Discharge (HID) system specially made for late model (97-03) F-150's/Expeditions.
You'll notice that they're a full headlight assembly replacement set... the light output is outstanding and can't be compared with a regular bulb like a silverstar. Of course, the system is a touch more expensive than a $25 bulb too.
RP
Lights
Hi, I actually installed the Nokya Artic White headlights and fogs in mine, only takes about 10 minutes. They are AWESOME, bright blueish-white, very cool looking, and they light up the Interstate at nite like an UFO, way better than any I see driving around, and they are very reasonably priced. I will never go back to the other kind. I bought mine through www.autothing.com , though I am sure you could find them elsewhere.
>>>>I just installed Silverstar 9007s in my headlights and the 9005s in my fog lights. I'm very pleased with them and especially the fog light upgrade. I'd recommend them for sure. I got them at Advance Auto Parts which is having sale on Sylvania lights including the Silverstars. They were buy one bulb for $19.98 and get the second bulb for half price. Plus they have a $6.00 mail in rebate to boot so once you figure in that you're gettin one bulb for $19.98 and the second for around $3.99. The most you can send in from one address is for $12.00 in rebates or two sets of bulbs. After the rebates I got both sets of Silverstars and upgraded my headlights and fog lights for around $50.00 after tax.
RockPick,
I should have known! [Both that the upgrade was more than just a bulb and that is cost more $$$]
I think I'll try the Silverstar route for now - especially noting the current rebate offer that I saw at Autozone and that is mentioned in another post.
I take it that the Silverstars are one of the best without replacing the entire headlight assembly.
Thanks for the note - btw, I frequent the "other f150 sites" every now and then, but this forum is by far my favorite
John
John
I took out my Fosser 80/100 Hallogen bulbs and put in SilverStars. I did one side and turned on the headlamps, and the SilverStar bulb looked to be a whiter and brighter lamp ( stock wattage ), when comared to the Flosser 80/100 bulb.
I have Silver Star bulbs in both my ZX-9R and my ZG-1000-A17 motorcycles as well. Makes a big difference there, with a single bulb ( ZREX is a 99, not the newer dual lamp series ).
Fog lamps, I have no clue on, I have the PIAA airdam and the PIAA 510 driving lamps, and 520 Crystal ION fogs lamps, so I don't have a way to compare those to stock with Silver Star bulbs in them.
Good luck
Good luck
RP
You'll find great instructions on how to change both headlight and fog light bulbs in your Owner's Manual. The 9007 headlight bulbs are a straight swap. The 9005 fog lights will require one minor modification to the tabs on the bulb. If you compare your stock bulb to the new Silverstar, you'll see one tab is a bit wider than stock. A quick trim with a pair of diagonal cutters will do the trick. Make sure not to touch the glass portion of any of the bulbs during installation because the oil in your fingerprints will cause a hot spot on the bulb - causing it to burn out early. If you need more help, drop us another post. I think you'll love the results.
