Wiring backup lights help
I attempted to wire my backup lights to the factory backup lights to a cab switch and a relay today and I am blowing fuses....
Here is how I have it wired:
I connected the striped factory light wire to the cab switch:
and I blew the fuse for the factory backup lights
I connected the black factory light wire to the cab switch:
and I blew the fuse for the backup lights
Any help would be much apprieciated
Tip
If I were adding more back up lamps I would just go to the source for the voltage. That's the Trans Range sensor.
By the vague schematic and the symptoms you describe, You have a short to ground somewhere. But I would tap into the
Black and pink striped wire from the range sensor and see if your new backup lamps work.
Good Luck!!
FordMasterTech
Good Luck!!
FordMasterTech
