The air bag light on my 1998 F150 4x4 , 4.6 ,Auto ,Super Cab Flash's 4 times , 4 times 3 or 4 times and then stays on after every start up. I would like to know how I can correct this fault code.
You need to be specific on what code/s it is.
Each code refers to a different fault.
Code 44 is a primary Crash sensor not mounted to the vehicle properly.
There is no code 43.
Thank's !, Have you ever fixed a code 44 ? It is a 44 ! , I meant the code repeats and then the light stays on . There is a picture of that sensor in the Haynes Manual. I'll check it out .
