reverse lights
reverse lights
I have a 93 F-150 XL with a manual transmission. The reverse lights stopped working on the truck a while back and I finally got around to working on them. I figured that it was a small chance that both lights failed at the same time so I replaced the bulbs. They still don't work. I examined all the wiring around the back of the truck and it all looks good. So I got a new reverse switch that fits in the transmission. Still no lights. I checked all the fuses and they're all good. Where should I go next?
dont need a lot of tools for electrical work but must have a test light to check for fire and ground. Dont just go throwing parts at it, do a little testing before hand will save you money and head aches. Power at hot to reverse lights? terminal pushouts at the connectors? Is it plugged into the tranny?
