12 volt Power supply
Thanx for all your help. I still have a few questions though as I am new to electrical systems.
The actual fuse itself does not have a hot and cold, it is where the fuse goes into that has hot and cold right? or wrong?
Because in my truck, the fuses are not all going the same way (some have the amp rating facing up and some are facing down)
And one more thing, i had a stereo shop install a deck for me. I just noticed on my radio fuse, that there is what looks like a tap coming off of it. But there is no wire attached to it. It is just a metal thing coming out from underneath the fuse. What is that?
Thanks again.
Thanks again.
No problem ask as much as you want and I will try to answer the best that I can, "if I can".
You are correct... A fuse can be used in any direction, it is just the plug in slot (AKA fuse slot) that has a power side and a non power side. Your fuse is just a piece of wire that can be unplugged. When you plug it in then it transfers the power from the hot side to the other and rest of the circuit. With it taken out, or blown then it is just like cutting a wire. The second part of the wire can no longer get power.
With a good fuse in then both sides have power, but if it blows then only the source side will have power. Because the wire (AKA fuse) between the two sides has burnt in two.
For the second question.
That sounds like it could be a fuse tap.
