01 supercrew driver door windowmotor
You will need a 3/4 inch holesaw. remove trim pannel remove trm pannel brace and carefully remove water shield and set aside, look throug access holes and find motor in the door shell you will notice three dimples (counter sinks) that line up with motor using hole saw drill thes out. thiss will alow you to acess the bolts and remove them after three bolts are removed un plug motor and remove, Reverse procedure to install Not necessary to do anything with holes If you love youre truck you may want to touch up the bare metal to stop any rust. Before drilling make shure there is no wiring that you will get into with the holesaw.
