12V outlet at rear of truck
Hey guys,
If somebody wanted to install a 12V outlet near the tailgate (for tailgate parties, etc...) what kind of wire would you use? I mean like what gauge would you use. Because it is running almost the length of the vehicle. And I was thinking I would tap into a fuse on the interior of the vehicle for my power and I was wondering what size of fuse to tap into. And also for an inline fuse how would I know what size to use on the inline?
Thanks, as you can tell I know nothing about electrial.
I understand where to ground it to, but you have to realize that I am a complete newbie at electrical and I am wondering about the other end of the ground. I mean you attach the wire to the battery and run it to the accessory. Where does the ground come in?
LOL, i know this sounds so dumb but like I said i am new at this and only 16 yrs old.
Ok, lets make it simple. You only need to run a red wire to the + of the battery. The black wire / connection on the outlet can attach right to the frame of the truck. Anything metal on the truck acts as the - wire. You can see this at your battery, as the heavy black wire goes right to the frame. This saves wire by just going right to the frame for anything electrical.
OK, wire time. I don't know how much power you need, or what the outlet you plan to use is rated for. But here are the rules...
If you need 30amps, use 10gauge wire and a 30amp inline fuse or circuit breaker.
If you need 20amps, use 12gauge wire and a 20amp inline fuse or circuit breaker.
If you need 15amps, use 14gauge wire and a 15amp inline fuse or circuit breaker.
Is this clear?
Adrianspeeder
Is this clear?
Adrianspeeder
That is exactly where I am thinking. Inside the box by the tailgate where the box kind of juts out into a square pillar type shape.
The only thing i'm worried about now is how to waterproof it. Any ideas? Wouldn't want it to start to rain when i have something plugged in.
