98' Strange beeps at startup
Indeed, it's probably the airbag light being burnt out. That's the only thing I can think of.... I think others have had that problem before. If you put the cluster into test mode (hold the trip odometer reset button in while starting the car, then continue to hold it for about 5 seconds) and check the bulbs. That should illuminate the airbag light (I think) unless it's toast.
-Joe
-Joe
