F150 Outside Air Temp Senosr
Temp sensor
I'm new to this site. I'm having the same problem with my temp. sensor. Have you had any success in fixing your sensor. I purchased a new overhead unit thinking the problem was in the main module but this didn't work. I can't find the actual temp. sensor that feeds this display. Can you help, Thanks alot.
Sean A.
Sean A.
Good job searching. But that post is ~2 years old, and the guy never came back.
The outside temp sensor is somewhere behind the front bumper or low behind the grille/headlight door. It's very small & looks like almost nothing. These are some older ones, but yours will be very similar. It might have a point.
