DTC Code for Airbags
LFC 52 indicates a loss of battery power to the restraint control module. There may be an open in circuit 937 to the restraint control module, a short to ground between fuse 2 in the battery junction box and circuit 937 at the RCM. Check fuse 2 in the BJB, and check your battery and charging system for starters.
Thanks for the answer. Do you know whether this indicates a recent loss of power (I just too apart and reassembled the dash and disconnected the control module), or did I forget to plug it back in? The reason I ask is that sometimes the codes reported reflect a recent event, no the exact condition at the moment.
Thanks again!
Thanks again!
