AM Radio static w/engine running
I sometimes listen to AM radio for news and sports. One station in particular (880), is reasonably clear when I am listening to it with the key set to "Accessory." However, when the engine is running, that same station is unlistenable because it is 100% static. What might be the problem?
I understand that when I use the blinkers or use the power windows that there is some static during use. But the problem I am experincing goes way beyond a reasonable amount of static.
Any hints would be appreciated.
Ed
Ed
I had the same awful reception in the same way, and it was a loose antenna mounting on the fender.
This radio is one of the best I have ever had.
On FM I have strong and weak stations on every slot down at the low end where the older radios will bleed over, this one stays clean.
I believe it has some form of digital processing to accomplish this ability to stay clean on the weak stations.
Originally Posted by dpostman
I think the Fender mounted antenna is for FM only. I'm assuming the AM antenna is probably a Coil inside the radio itself.
Sorry that I can't offer a solution for you at this time
dpostman
dpostman
