Right turn signal works part-time
I have a 97 f-150 when you turn on the right turn signal it sounds like it is working but no flash on the dash and no front or rear signal. If you turn it on very "softly" everything works fine. Also it seems to work better later in the day when its hotter out. The left signal works fine all the time. Is there some contacts on the switch that the arm goes into and how do you get it out? Thanks Jim
