P1405 Problems
Look on the drivers side between the large black power brake cylinder and the intake.
There is a small black device with a connector on it standing on two small vertical pipes with short rubber hoses.
Make sure their both pushed onto the small pipes. One is a little larger than the other in size. They must match up.
Happy to hear it was that easy for you.
The device is a test sensor that tests the ability of the exhaust to flow to the EGR and in the correct volume.
The two hoses have a restriction between them that the sensor flow differencial is measured accross, with the EGR commanded to flow at close to a 10% opening point. These are the two calibration points used to report back to the computer and will see anything that is faulty from wiring, sensor, hoses, blocked calibraton holes, poor operation of the EGR ect.
So, comb your hair before you get into your truck; the computer is looking at you.
