Optima batteries
Basically, for the guys in the car audio industry Optimas are GREAT because they are FULLY sealed and can be placed in unconventional locations (ie in the bed, in the truck, trunk, etc) and will be safe doing so. but for your normal starter battery, it really is not worth the added cost. I'm SURE if you calculate the cost ratio there are more economical choices out there that will give the same performance (just not as well sealed) for the average user just looking to replace the factory battery.
I put an Optima battery in my truck and at first I used the little plastic "OPTIMA GROUP 34/78" adapters that came with the battery, big mistake. They do not hold up well when driving off-road if fact mine broke off and the battery started bouncing around in my engine compartment. Here is what I did:
1. Purchased a Billet Aluminum Optima Battery Hold Down from eBay. (see link below)
2. Removed stock plastic battery tray.
3. Drilled holes for billet hold down in the sheet metal base under the OEM battery tray.
4. Purchase 1 10" rubber tarp strap, remove the metal hooks, take the bolts the where used to hold in the stock plastic battery tray, and put them through the holes at the end of the straps, screw the bolts back into the original location where the held the stock plastic battery tray, stretch out and put the plastic box that was behind the stock plastic battery tray to hold in place.
[Stock OPTIMA GROUP 34/78 Adapter - "NOT RECOMMENDED"]
http://www.optimabatteries.com/publi...nd_height.html
[eBay Motors search for "optima battery hold down"]
http://motors.search.ebay.com/optima...fsopZ1QQfsooZ1
[10" Rubber Tarp Straps]
http://www.acehardware.com/family/in...v_catlinks_txt
Originally Posted by Quackaddict
I have had a couple and will have some more. If you have a regular truck with a couple of simple not elec. heavy mods and there is nothing wrong with your battery I see no need to run out and buy an Optima your stock is fine. Autozone batteries on a truck used for a DD with no super elec mods are fine if you replace the stocker for whatever reason.
Now once I have my Winch, Off Road lights, Electric fans, and sound system I am going to upgrade because I have had such good luck with the Optima for supporting these type of mods etc.
Optima's are awsome if you need one they aren't for everyone and I think that is the only reason not to buy one is you simply don't need it.
My OEM battery is only 4 years old but there is a problem with the negative battery terminal corroding. The vent wells are not overfilled, I cleaned the battery last month, and even replaced the terminals and added treated battery washers. I popped the hood yesterday and the negative terminal is already corroded again. I can only assume there there is a minute crack or problem around that terminal area so I decided to just replace the battery and be done with it. The local Ford dealership wanted $85 for a Motorcraft BXT65-650 (750 & 850 same price as well) w/ 3 yr free swap (100 month total) which may have been a better buy in the long run.
Guest
Posts: n/a
Originally Posted by yamaha619
How do they hold up in the hot heat of Arizona ?
I needed a new battery a few months ago, and wanted to get an Optima. A friend of mine has a connection with Exide, though, and was able to get me an Orbital for a great price. I did some research, and the Orbital seemed to meet or exceed the Optima in every test I could find, so I figured I'd give it a shot. So far no regrets at all. Very pleased.
Im a big fan of the Optima Red Top. I had the same on in my last two Subarus. It is about 3 years old and still works great. Im in Maine where it gets cold in the winter and its nice to know that the truck will always start. 900 CCA's are your best friend after your vehicle has been outside in zero degree weather for 10+ hours.
