Keyless entry
Originally Posted by defective
Well I was kinda hoping that with the factory system the wiring is already in place and all i had to do was buy something and plug it in.
If you followed the procedure to add in new RKE fobs, and the locks did not cycle, it is not there.
One thing, when I added one to my '01 SCrew, it took me 3 times to get into programmng mode. I didn't think I did the process any different, but the 3rd time I enetered programming mode, put in the 2 factory ones, and added the 3rd one to the system.
Maybe try it 2 or 3 times, I had to really haul through the on-off sequence to get it to go into programming mode, the amount of time to hit the on-off sequence in the manual, I thought I was within this time frame, but the frist 2 times I obviously was not.
As for adding in a RAP, I recall the Keypad modification the harness was not in the truck like the '00 + trucks, the wires had to be added into the harness. This is for a keypad, but just some info on the topic of complete wiring harness or not.
Originally Posted by Friday13
Defective, did you have any luck finding a factory keyless entry receiver? I am looking for the same thing for a '97. Is this a plug and play part?
Drop a call into Travis at KCAutoSound. He has an extra fee, where he will setup the unit for your specific MY and truck, and include the wiring directions, if you don't feel like searching here for the DIY remote installs.
Originally Posted by GIJoeCam
The 97-03 and 04-ups are completely different. On the 04-up, if it didn't come with it from the factory, adding it will not be easy unless you go aftermarket. For OEM parts, you'd be better-off taking out an ad in Truck Trader and selling it for one with more options.
-Joe
-Joe
Adding a Powercode alarm/keyless on a 2004 up is pretty easy.
Chris
