ABS motor
Are you sure your correct on what you are saying?
Is there a yellow warning lamp on?
Where is this 'motor' located?
Actually a motor associated with ABS is used on vehichles with an electric pump driven pressure system (no vacuum).
Do you have such a system or is it vacuum operated?
I find no part like that in my book unless it has been left out.
Reason I ask these questions is I own a car with electric pump brake system and it does have a motor and associated electric control module and power relay.
On a system like this if there is a pump problem the brakes usually also have a problem and make the car undrivable.
This is why I question what problem you really have. Maybe it's some other motor that is stuck running.
The motor I am refering to is located on the drivers side under the air filter housing. It has 2 electrical connectors on one side and several (4 i think) brake lines on the other.
It has an electric motor and a little flat black box attached to it on top.
Yes the ABS light is on.
I pulled the fuse out and the motor stops. But i can't find a relay for it.
:o
:o
after i take the module off ..can i take it apart to look inside and maybe add some dielectric grease or something?
BTW the screws hold the module on to the motor look in bad shape! lots of rust. I may have to use an easy out adapter.
Is buying just the module an option or do i have to buy the whole motor assembly?
The same thing happend to me a year ago. i went to the ford house and they would only sell the motor and module together. It was going to be around 750 for the parts and then labor was going to be another 250 or so. I went to a salvage yard and bought a used pump and module. Then took the salvage module off the salvage pump and put it on the pump already in the truck. It has worked fine for me.
