Help! Ignition Switch Problem
My Engine wont stop running. I had to pull the coil wire from the distributor to shut down my engine. I figured it might be a faulty igntion switch. I replaced it and the engine starts but wont turn off. I am stuck and need truck for work by MONDAY can someone help? I also learned the 12v key on positon stays on even if the switch is on key off position. And the old ignition switch was warped and burned. The female connector was in worse condition. It cracked in half. Also i need a diagram of the wiring to this particular problem. Please help someone!
