Ford 1998 F-150 4X4
on
The engine section is a better place for this.
Please fill out your profile, with the truck info, or make sure to put in the engine size in your post.
Also make note if you are getting a flashing or constant on CEL ( check engine light ) as you should be getting a flashing light ( DTC : P30x ).
If you have an AutoZone around somewhere, take the truck there, and have them scan the code, and write down al the code numbers, not what the guy thinks is wrong.
Miss can be a lot of things from the plug to a COP / coil pack ( this is why the egnine size is important ) and then down to the other items like a CPS, and I forget the others.
Maybe take a search on the term [/i]P300[/i] or change it to P301 or P302 etc, to find some threads on it in the mean time might also prove useful. Just something to look at when you post this in the Engine section.
