Power Window Motor Options
I need to replace the power window motors in my truck, and upon taking one out last week, discovered that it looks very similar to the ones in my '89 Crown Vic. There's alot more Crown Vics in the junkyard here than there are F150s. Does anyone know, or has anyone attempted to use a different window motor in their truck?
Mike
Junk yards use a system of numbers from a book by Hollander (sp?). If the power window motor for the '89 Crown Vick is the same Hollander number as the power window motor for the 'xx F150 it will be a bolt- in replacement. The Hollander books are very expensive but you might get someone at a junk yard to give you the numbers. BTW- if the parts are slightly different but can be used as a replacement, the book will usually note that. Try a dismantling yard first ( where the parts are pulled before you get there) as they will be more likely to use the Hollander numbers.
