shutting off dome with open door?
on
If you are not doing it all this often, you can just pull the Interior Lamp Relay when you have the doors open.
This is kind of a Chevy on cinder blocks method of doing it, but it is real quick and easy.
The other thing you could do if you wanted a switch is to use the same concept for the Fog Lamps on with Low and High beams thread :
https://www.f150online.com/forums/sh...d.php?t=233430
With either method, rather then attach the ground pin to ground directly, route this via a switch, so you can shut off ground to the relay coil, and this will disable the relay itself, just like unplugging it.
Don't know if you feel like doing this type of mod on your truck, if so we can get into it with a bit more detail.
Joe's way is just as easy also.
Let us know.
Let us know.
Ive always just rolled the latch back. The switch idea is pretty neat tho. might have to do that someday when im bored... And ive tried to close my door plenty of times with the latch rolled back, but i tend to not slam my doors anyways so its not a problem.
We worked on a dodge at school and it pinged/beeped even if the keys were out of it, if the door was open. PITA but then again we were pulling alot of dash components out, so i think the truck thought the headlights were on....
And EDIT: Scully i pmed you
-Patrick
-Patrick
