Would like a suggestion about fog lights.
I searched and searched and couldn't find this anywhere so i'm gonna ask.
the tab that holds my mfs on broke so now i cant turn my fog lights on without a set of pliers. ive tried hot glue (that worked the longest) elmer's glue and gorilla glue. none of them worked to satisfaction as i am still without fog lights that i can turn on easy.
what i want is to be able to turn the headlight switch and the foglights come on. i can turn the fogs on with the parking lights so i was wondering if i used a tap to connect the wire powering the fuse of the parking lamps to power the fuse of the fog lamps. i am assuming that there is only one system powering the parking lamps so the fogs will stay on when i turn my headlights on. thanks in advance. also, if anyone can give me wire colors id be much obliged.
