2005 XLT wont run with headlights on
I hope somebody can help me. Last night when getting into my truck it would not start. I always have the headlight switch set to the automatic on (autolamp) position. When I tried to start the truck it wouldn't start up. I made sure the gear selector was in park and started fumbling around with the headlight switch in case I had a dead battery and noticed it would start fine when the headlights were in the off position . After the truck started I turned the lights on in regular mode and it shut down the engine!!! I then tried every putting the switch in every imaginable position and the truck would only start or run when the switch was off.
Out of frustration I started to drive the truck on a well lit road for a few hundred feet until I had to turn onto an unlit street. While driving I turned on the headlights and this time it didn't shut the engine off. I didn't dare mess with the switch again until I got home. Everthing worked fine until the same problem happened again this morning when getting ready to drive to work. It's a no crank - no start situation. As a matter of fact, If I turn on the headlamps or parking lights while driving the truck shuts off (stalls).
If anyone has a clue as to what might be happening (or know somebody who has had this happen) I would be thankful.
