07 low air light ?
Aren't the sensors in the valves?
Do you still have the other tires? I could have sworn a friend of mine told me that those valves are like $100/each to replace or something along them lines.
I wonder is there a way then if you did transfer the valves to set those sensors to be able to monitor the new (different from stock) tires. Then again, pressure is pressure - 32 or 35 psi should be the same no matter what tire you use.
Wish I knew something more to tell you but I'm just a standard no nothing kinda guy who takes my truck to the garage for oil changes/brakes/etc!
