94 F150XLT 4.9L 5-speed multiple electrical
I bought this truck new in 94 and it has never failed me. I washed it this evening and when I started it up, the wipers were running. I had to disconnect the motor wiring on the motor to stop it. Did a search and info says windshield leak. OK, I'll buy that since I recently had a new glass installed. However, before this, the cruise no longer works, the horn doesn't work nor does my flash to pass hi beam function. I'm assuming my issue is in the pin contact ring under the steering wheel. Likewise, I've had the 32 flash code from the air bag light for past several years. I think its time to fix that annoying light. Do you folks concur with my thoughts................even tho I've never had the steering wheel off. I just think its odd that all of these other issues (all seem to have switch functions on the left side of the wheel) would not somehow be related. Is there a partial harness/switch assy that can be replaced?
Overall this has been an awesome truck. 223k miles and still has the factory starter installed..............has never been off the truck! Gotta love a FORD!
Thanks for the help
Thanks for the help
