Power Source tap
Power Source tap
Hi all,
Been lurking this site for a long time doing my research.
Finally bought an '07 Screw FX4.
I'm trying to mount 2 sets of PIAA driving & fog lights. PIAA has changed from a toggle switch to a push-button on/off switch with an LED indicator light that requires a separate power source since I last purchased a set from them.
The source just needs to power the swithch/LED. I don't want them to be controlled with my factory headlights/fog lights as I want to control them whenever I want. I thought about tapping into the cigarette lighter, but that has continuous power and not sure if I should be concerned about battery draw when truck is off, though I suspect it would be minimal, it would still draw some power. Thought about just tapping it straight into the fuse box too, but same issue with continuous source. I also don't want to tap into anything connected to the sat radio/nav system.
Any suggestions on a good tap point for just the switch that would only be powered up when running and independent of the headlights?
Thanks!
Thanks!
