99 both barke lights out - bulbs & fuses ok
All other light functions work ok - Head light, reverse, blinker, both turn indicators. Also the windshield wipers function properly although I had been experiencing the wiper making one switch when I used the turn indicators for a long time before the brake light problem happened.
Any advice will be appreciated. I cannot drive the truck in this condition (Most people these days don't know what a brake hand signal is).
KAPA
KAPA
If you are sure the bulbs and fuses are OK, you might want to check the brake light switch. It could be stuck or bad. I do not know exactly where on your truck it is but it should be at the top of the brake pedal arm and may be attached to the steering column. When you push the brake it should release the switch giving power to the brake lights. HTH
