Rapid Turn Signal
Rapid Turn Signal
My left turn signal on my 2008 Screw just started acting crazy. When the left turn signal is used, it clicks rapidly, maybe twice the normal speed. However, the front signal works while the rear does not. The rear light comes on but the turn signal doesn't work. I removed the rear bulb and I don't see any burned filaments. Is the relay box at fault? How would I check it? BTW I would check the fuse, but I can't find the fuse box!?
HYPO
HYPO
HYPO
HYPO
Quick check, put on your brakes, do both brake lights work ( leave the parking lamps off when doing this test )?
