highbeams
actually, you can do this very easily yourself. all you have to do is add a diode into your headlamp wiring. if you add a diode in between your high beam and low beam wire, you will allow the low beam to stay on while the high beam is energized. if you install it with the band side of the diode on the low beam wire, you will be good to go..... just solder it in and your all set. and, you only need to do it on one side, and both will work off of it.
the only other thing that a "bright box" or aftermarket harness would offer is a higher voltage by means of using a relay.
