blowing fuse #4 and no dash or marker lights
blowing fuse #4 and no dash or marker lights it all started with melted factory towing harness which is also part of taillight harness cut out connector and repaired wiring now blows #4, 5 amp fuse when nothing is on and smells like circuit board burning inside cab, any help on what to check or do would be oh so helpfull
Another question.
When you have the main headlamp switch in the off position ( not in Autolamp ), do you still have this problem with the fuse blowing ?
I am assuming this is the cab fuse panel, fuse #4, that you are talking about.
This is for the Autolamps, power mirrors, and RKE / RAP.
If this fuse is blowing, it could be incorrect install of the trailer tow adapter, or the autolamp module has taken it's leave.
What exactly did you do when you "cut out connector and repaired wiring " on the melted harness.
took the melted factory connector shown in the diagram obove that is circled and butt connected them together with the shrinkable butt connectors when the problem started i also recut all those butt connected wires and the problem persist
and to my knowledge this truck never had auto lamp feature unless it never worked
took the melted factory connector shown in the diagram above that is circled and butt connected them together with the shrinkable butt connectors when the problem started i also re-cut all those butt connected wires and the problem persist
There could be a problem with it still.
On the topic of Autolamp, does the main headlamp **** have on the dial a light bulb with an A in it ?
You basically unplugged the connector, or you actually did unplug the connector? Simple question really.
