1997 f150 gem
on
Yes it does. Generic Electronic Module is for controlling things like 4x4 shift on the fly, delay wipers, interior lamps, accessory delay items to name a few.
On the -'03 MY trucks, the GEM is located on the back side of the cab fuse panel. Bolted right to the back of it.
Nice dealer you have there
Directions Steve posted on the cab fuse panel removal, to give you a better idea on where it is at.
https://www.f150online.com/forums/el...use-panel.html
SSCULLY I wrote earlier about a power window dilemna. Well I replaced the master board and worked great for a few days. Now again sometimes the left window won't work in the regular mode or one touch. I also have a different window motor that sitting in the garage. I was told the GEM regulates the left window. If so is there anyplace besides Ford to purchase one. I don't have any other electrical problems beside the window. Thanks a million.
on
The GEM does control the left window.
Was the master window switch you got new ? This sounds like what happened to my '06, which was a faulty master window switch.
2001 Power window, should be close to the same on your MY. Note where the switch is triggering the GEM, and the GEM controls the motor use.
on
Online sites ( no specific order )
www.oemfordparts.com
www.tascafordparts.com
www.thinkpartsguy.com <- site sponsor
http://www.fordpartsonline.com
www.directfordparts.com
www.fastpartsnetwork.com
That function with the switch still points to a bad switch. Mine would operate one way fine, but the other no go. I really had to mash it to get it to get, and then the day I got the new switch, I tried it and nothing, dead in one direction.
on
I would guess that switch has been WD-4's or contact cleaner'd, and it is gumming up in the cold ?? That is a SWAG at this point.
on
any 1997 to 2003 for your cab type would work from teh description. Go to a 21003 MY truck, same as above :
Window switch, f150, front, left, w/o super crew - f150 1997-03, heritage 2004 - F150 1997-03, HERITAGE 2004 02-04 $81.60 $53.86
on
There is another on St Chas in Lombard, drawing a blank on the name. Between Maple and Grace.
