abs fault
abs fault
i have an 04 fx4 and my air bag light flashes several time sand then stays on what would be a good scanner to read a possiable code?
also my my mechincal friend has a otc genisys that is a 2.0 2005 for $350 would this be a good price?also would i be able to use it usefully on my truck?
Next time you get a LFC, count the flashes ( would in a 2 digit format ) to get the problem.
Got me if that is a good deal, considering you don't need it right now why bother ?
You can always have Autozone scan the ( powertrain ) codes. Don't know if that one does body codes or ABS codes, or just eh same powertrain codes that you can get for free from Autozone.
