fuse keeps blowing
fuse keeps blowing
my RH low beam headlamp fuse on my 2008 f150 keeps blowing. ive had my hid's in for 2 months now and everything was working good until the fuse blew, i tried replacing it with another 10amp fuse and continues to blow, i have also tried a 15 amp fuse and that dosent work either. any help???????
Are you powering the HID ballast from the factory connector ?
If so, pull the ballast off the factory connector, install a standard bulb in the bulb connector, and install a fuse, and see if it blows.
If the standard bulb works, there is a problem with the ballast or the wiring from the factory headlamp connector to the ballast.
