Stereo Staying on!
Take a look at this thread, seems to be the same symptoms.
https://www.f150online.com/forums/el...door-open.html
Hey,
I have the same problem.. it happened to me this weekend, i have a 2008 supercrew and all the door ajar lights come on fine except the drivers door. i read all i could find about this, i tried wd-40, i checked the wires for corrosion, and didnt see anything. which looks like it was fixed for my year in the factory. so i though the door switch was bad.. no luck i replaced it with a new one and nothing. radio stays on, no door ajar light, no dome light, and windows will work, at this point im out of ideas. so until i can get it fixed everytime i pull the key from the ignition i have to open the passenger door to turn everything off
anyone have any ideas ?
The VSM is mounted behind the seat back, below the window, towards the driver's side.
This wire will have ground switched to it ( ground and no ground are the states ).
well after checking the wire i found one bad wire ( the yellow and black wire)
so i fixed it and it gave me a bunch of new problems..
well i had enough and decided to take it to the dealer for them to charge me $90 just to look at it, and low and behold there was one more bad wire and a bad ground. so i had them fix it while it was torn apart which was also not cheap, but every thing is working fine now. so if you want to avoid a $215 dollr bill, i would say get a meter and test all the wires from the drivers door to the vsm in the back..
