Flareside Lower Tail Lights not wired for brake
Does anyone know the post that described how to wire the lower tail lights so they also illuminated when the brakes are applied.
I have taken the lights apart and I can see the contact for the lower brake light is not available.
Thanks in advance,
Richie
99 Oxford White Supercab with Line-X
Thanks in advance,
Richie
I did the light thing you are talking about. It is real easy there is a rubber grommet thing that you have to force a wire into on both the top and bottom bulb. Check out WWW.fseries.com they have a really good tech article on this mod........steve
http://njf150truckclub.homestead.com/index.html
www.my-f150.com/steveo
steveo@f150fanatic.com
[This message has been edited by steveo (edited 06-30-2000).]
- -1999 Ford F-150 Supercab Flareside ORP
- -4.6 Liter V-8, Auto, 3.55 LS Rear
- -Deep Wedgewood Blue
- -Lund Lighted Moon Visor (painted)
- -Lund Interceptor Bug Guard (painted)
- -Deflecta-Shield Window Rain Guards (painted)
- -Delecta-Shield Slotted Tail Light Covers (painted)
- -Manik Grille Guard
- -Ford Factory Cab Steps
- -Extang Soft Bed Cover
- -Yellow Under Car Strip Lights
- -Tinted Windows (5% totally illegal)
- -Pioneer P725R CD Player w/Flip Face Head Unit
- -Superwhite Headlight Bulbs (from Online Store)
- -K&N Air Filter
- -Air Box Silencer Removed, Tail Light Modification
- -Cranked Torsion Bars to Level Truck Out
I found the previous post after some more searching around. If the link works, here it is: https://www.f150online.com/f150board...ML/000492.html
If not, it was posted by ROUSHFAN-1 ON 04/02/2000 and the topic is PRE 2000 FLARESIDERS....
hth,
Richie
hth,
Richie
