How do you tie into Accsesories?
Easiest thing to do is get a test light and start checking the wires in the area you wanting to make the splice. There are many different wires in many different locations that are active in the acc. position.
Sven
2000 F150 XLT 4X4 Off Road 5.4L Reg. Cab 3.55
Performance Enhancemets:
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
All of the above, plus
Sony C7000X HU
Cerwin-Vega SS2502 components(Front)
Blaupunkt PCxp573s(Rear)
Radio-delay mod
(For now)
Sven
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
Sony C7000X HU
Radio-delay mod
(For now)
This is probbably a stupid question but how and where do you tie into accsesories? I've been looking and can't find where to do it. Thanks
98 F150
Midnight Blue
4X2 Super Cab
4.6L V8
Viper alarm w/ remote start
Tuff Grip spray in
SI/DO Ravin Z-33
BFG 32" ATs.
98 F150
Midnight Blue
4X2 Super Cab
4.6L V8
Tuff Grip spray in
SI/DO Ravin Z-33
BFG 32" ATs.
You can wrap the bare wire around the fuse and then insert the fuse if you want. That's harder to do the the mini-fuses though.
What exactly are you trying to install?
'98 F150 S/C 5.4 V8 4x2, Aggie maroon, spindle lift, blocks and leafs, Rancho RSX shocks, Airaid filter system, Pro Comp 305/70/16, AR Baja 16x8, Dynomax duals, and some other stuff
Thanks. Well I was trying to do this with my amplified speaker for my CB. As it turns out though the speaker has A timer on it so it shuts it self off after a certian amount of time. I sill would like to know though incase I ever get something that I would like to tie into the accesories anyways.
the black wire with the pink stripe that connects to teh back of the stereo works for accessories. It's only "live" when the key is in the acc. pos.
-AR
2001 F-150 XLT 4X4 Off-Road, S/C, FS, Black[*] 4.6L Triton V8 HPI[*] 5 Speed / 3:55 Reg. Axle[*] Keyless[*] Premium Audio CD
Mods:[*] K&N Cold Airbox / Throttle Body Mod.[*] Flowmaster 40 (3" x 20" "Turn-Down") [*] Cranked Torsion Bars[*] APC XENON PLASMA Super Whites[*] Bugshield[*] Bedliner[*] Ventshades[*] "Light Argent" 4X4 Off-Road Decals[*] K&N & Flowmaster Stickers (Under the Hood)
Audio:[*] Rockford Fosgate G360A2 Punch Amp[*] JL 12W3-D2 (JL ProWedge Box)
Build Date: 8/23/00 (Kansas City Plant)
arobbins@mail.liberty.k12.mo.us
-AR
Check out this post regarding the Add-A-Circuit:
https://www.f150online.com/f150board...ML/000225.html
Jimb...I tried the add-a-circuit on Saturday to add power for my radar detector...worked like a charm. I added into slot 5 and the only catch was that I needed to trim the inside of the fuse cover in order for it to snap back on. Just a little trimming and it worked like a charm. Much safer and neater than pushing wire under a fuse. Good Luck...
Ron
1997 F-150 XLT SC 4x4 5.4/Auto
Ron
