no back running lights or plate lights or fog lights
Everything else works...checked all the fuses...they are good. Turn signals work. Front running lights work. Checked them with a test light. Getting power only when the turn signal is on? But no power when i turn the lights on for the tail light to stay on? Any ideas? 2000 f150 4x4 extended cab 5.4
If the fog lamps do not work, has the fog lamp mod been done to the truck ?
http://www.svtlightnings.com/svt/how...s/foglamps.htm
What does its kinda messed up mean for the trailer tow adapter ?
Time to check for power at the bulb connectors, you could have burnt out bulbs.
Don't know, 2nd time asking, What wires are missing ?
i replaced al the bulbs in the tail ligts. When i put a test light on them...i only got power when they were in turn signal mode. Other than that no power. Which is leading me to think...the headlight switch? As for the 7 pin adaptor...to be honest i reallt dont know what wires are not connected. But i did re splice them. And it changed nothing. So i am kinda scratching my head over this. The fog light bulbs look fine. So thas why i am thinking...maybe the headlight switch?
ok...so i went back out and messed with it. Under the reat of the truck where the lighting is...i found a wire that was ungrounded. It was light green and yellow. So i grounded it. And nothing. So on the driverside...rear of the truck i pulled apart the tail light male and female plug. I could not get it apart. So when i did...it pulled some prongs out with it. It was very corrodid...and not i cant get it back together. So tomorrow i will get a new male and female ends...and hope that that works.
