Electric window failed swiches
I have had 8 window switches installed over the last 7 months (5 in the last 3 weeks). All of the switches are on the driver’s side panel for the front passenger window. The switch only burns out for the down direction, but never burns out during use. Ford dealer has replaced window motor, wiring harness (from window from window) and a sending unit ?.
Has anyone had this problem.
Could be passenger side window switch
I've never heard of this but I'd ask the dealer to replace the PASSENGER window switch. I haven't looked at the wiring diagrams for some time but I believe both the driver's and passenger's switches control the same relay for window operation. A defective passenger switch could be causing excessive current to flow through the driver's switch. It sounds as if they've checked out everything else. I'll try to locate my shop manual and look at the wiring diagram when I get home. Just moved and everything is in boxes so don't hold your breath. Good luck.
