97 F150 - power windows work w/o key?
on
No, I don't think it is a problem, I was more concerned with a security risk. If the power windows work all the time, it could be easy to break in with a coat hanger (simply push on the button to lower the window). The way it works seems to make sense... The windows will work for a while after the ignition is turned off, but this is overridden as soon as the door is opened.
