Installing a turn signal mirrors elect.cntrl. module
I'm looking for the wires under the drivers side dash panel coming from the turn signal relay going to the left and right outside mirrors. I don't even know where the turn signal relay is located at this point.
I'm also looking for the auto Xmission reverse signal wire and the door ajar/open signal wires. A 2002 F150 supercrew wire color code chart would certianly be nice right now. I'm not too comfortable probing the several hundred wires under the dashboard not even knowing which ones belong to the air bag.
Can't seem to find any manuals with diagrams at any parts stores or on the net. Where can I get the wiring diagrams for a 2002 F150 Supercrew?
Hi E Welcome!
Yes, lots of wires. I dont know fix..maybe someone here does.
Meantime try www.helminc.com Maybe they have one?
Good luck...OT
Good luck...OT
The web site "the12volt.com" only has wire color codes for alarm systems, audio systems, or remote starter systems. It was not a whole lot of help for installing an electronic module for turn signal mirrors. Because it doesn't give you the color codes for the wires coming from the turn signals, door ajar, or reverse gear.
I now have a new problem. I tied into the yellow 12v constant wire on the steering column and the black/green 12v accessory wire on the steering column and the Red/green brake wire on the brake switch. Now the power windows are not working.
I looked to see if I had accidently disconnected something but found nothing. The new wires I added are not hooked up to anything yet so this makes no sense to me as to how the power windows could have been affected.
