Flomaster 2 chambers, or 3 chambers...whats the best?
I called some local muffler shops and for a v-6 they said to keep the stock 2.5 inch tubing and replace the muffler. Now they kept saying go with the 2 chamber because the truck has 4 catylic converters so there will be very little in cab drone. But everyone on the board is using a 3 chamber (40 series delta) of which they said doesn't change the sound a great deal because its a 6. So what dod you guys think?
1999 4.2l 2wd super cab F-150 3.55 gears LS Mods: 3in body lift, 285/75 R16 BFG AT, suglid tonuea cover (white) 10 disk changer K&N Air Filter Tow package 6000 Lbs GVWR
Things to come: 4.10 gears, Flowmaster 40 series Delta, Superchip, Grill
I see why you may be confused. All of the flowmaster 50 series are 3 chamber mufflers. All of the Flowmaster 40 series, whether Delta Flow or not, are two chamber mufflers. You can keep your stock 2.5" tubing and replace the muffler with whatever you choose. The 40's will give you more sound and drone when compared to the 50's, so it's kind of a trade off.
Click on any pic below for a closer look:
<A HREF="http://www.zing.com/picture/p8bbc38a6b8da7299901c07d2740149c5/ffaf352e.jpg.orig.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p18dfc566f482837068e8ff7599500eac/ffaf3443.jpg.orig.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/pbe7cf6fd92bd647780a60a53170b215f/ffaf34dc.jpg.orig.jpg" TARGET=_blank> </A>
2000 XLT Sport, Flareside, 2WD, SuperCab, 5.4L. Factory options: 3.55 LS, Class III tow, Dark graphite captains chairs & console w/CD changer, Remote entry , and Slider.
Mod Highlights: Window tint, light covers, Linex bedliner, ARE LSII lid, Flowmaster cat-back exhaust kit, and a Classic Design Concepts front bumper cover.
Wish list: K&N FIPK, Belltech 3/4 drop, rear sway bar, and a SuperChip.
For details, go to: <A HREF="http://home.columbus.rr.com/selva1/f150.html" TARGET=_blank> </A>
[This message has been edited by selva1 (edited 07-26-2000).]
So what is the difference between the regular 40 and the Delta 40? The Summit catalog (pg 171, Jul-Aug edition) describes the Delta Flow Tecnology as having 3 internal baffles. Then when you look at the Delta 40 Series it states 2-chamber. A bit confusing, maybe I can't see the Forest for the Trees?
Y2K Lariat Flareside SC
5.4, 3.55 Limited Slip
Class III Towing Package
6 Disc CD Changer
Captains Chairs
Bright Red over Silver
MODS:
Bugflector II
Herculiner Bedliner
Clear Corner Lenses
Custom Scratched Tailgate
Future mods (just a couple more days of caseing the banks now):
Superchip, Airaid FIPK and exhaust.
6 Disc CD Changer
Captains Chairs
MODS:
Bugflector II
Herculiner Bedliner
Clear Corner Lenses
Anyway i went and got the 40 series delta put on today. I kept the stock tubing because the v-6 won't get enough back pressure through 3 in pipes. But I like the sound. The in cab isn't too bad either. 168 after for the muffler, install, chrome tip, and moving the exit pipe upwards 3 inches because of the body lift.
1999 4.2l 2wd super cab F-150 3.55 gears LS Mods: 3in body lift, 285/75 R16 BFG AT, suglid tonuea cover (white) 10 disk changer K&N Air Filter Flomaster 40 series Delta Tow package 6000 Lbs GVWR
