Heat Riser
The sring probably broke and it was making a racket so they welded it open.
Just a guess????
Check out this guy's explaination why he wired his open:
http://www.eng-tips.com/gviewthread..../108/qid/40078
Just a guess????
Well, since the heat riser is supposed to supply heat from the exhaust to the automatic choke during engine warm-up, it might affect your gas mileage if it was closed all the time. This would cause the choke to close down more creating a rich condition and poor mixture ratio at normal operating temps. If the heat riser won't open up on it's own, then I guess the best solution would be to fix it or wire / weld it open. This is just my guess...maybe someone else here can give some expert advice.
