Flowmaster Delta 50
Flowmaster Delta 50
I need some of your expert opinions. I'm thinking of replacing my stock muffler with a flowmaster Delta 50, leaving the stock pipes. My question is what kind of performance gain or sound quality will I achieve by doing this or am I just throwing money away? Any comments would be appreciated.
2000 XLT SPORT FLARESIDE SC SB LS 4.6 AUTO, SILVER,
WOOD DASH KIT,
SPEED GRILLE,
FORD DURALINER,
PREMIUM AM/FM/CASS
WITH 6 DISK CD CHANGER.
WOOD DASH KIT,
SPEED GRILLE,
FORD DURALINER,
PREMIUM AM/FM/CASS
The FM Delta 50 muffler only change is not a waste of money and does increase performance. It flows approx. twice as much as the factory "garbage can". The Delta helps quiet interior resonance. This setup is not loud due to the cats cutting down on sound levels. This will require adding/fitting a bit of pipe and one hanger. The total cost of muffler and install will be approx. half the cost of a cat-back system. Good Luck !!
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Robin,
I had a Flowmaster 50 series Deltaflow installed on my truck, and am very pleased with it. 2.5"inlet & 2.5"outlet. It was installed as a direct replacement, at a local muffler shop for $120. parts and labor. They added extra pipe, due to the shorter length of the Flowmaster. No loss in torque, noticeably louder and better sounding than stock. Feels and sounds faster to me. But definately not too loud, or annoying in the cab.
'99 F-150 XL supercab, flareside.Oxford White, 4.2L Auto.,3.73gears.
2"/4"drop, Superchip, Flowmaster 50 series,
TransGo Shift Kit, Airaid, Hellwig rear anti-sway bar.
Spal power door locks, keyless entry.
