Flowmaster Vs. Magnaflow ???
Im looking to do a Duel rear exit on my 02 5.4 My two top runners are the Magnaflow and Flowmaster. I have no epierience with Magnaflow. I looking for a good sound and decent power gains, also next year Im looking to bolt a 9lbs ati charger on.
So anyone with any opinions on either, advise, maybe a free cat back exhaust?? haha.....well thanks in advance for the posts
I don't know if anyone here has any experience with the dual out rear Magnaflow yet. I have been waiting for mine for almost 5 weeks now. I had a Flowmaster which I liked the sound of, but the aluminized pipes rotted out in 3 years of NY salt. The Magnaflow is stainless steel and should last considerably longer. If I get my Magnaflow sometime this century i'll let you know how it is!
If you are looking to bolt on a supercharger at some point, I would say skip either system. They both use 2.5" single input. I recommend going with a dual 2.5" in system, like those designed for Lightning or supercharged HD. They will work better for your future mod. Dual after the muffler is nice, but if it is restricted to single 2.5" between the y-pipe and muffler, why bother as far as performance goes? You'll be limited by that single 2.5" section.
Hey sdf150guy,
I see from several posts you like flowmasters. I want to put some 40 series delta flows on my V6. What size inlet and outlet do you reccommend? I was thinking 2.25 in and out because i dont want to loose any low end. I think that the stock pipes are 2.25 in diameter right? I also just plan to get it dumped right after the muffler(if that makes a difference?) 2.25in/out or 2.5in/out?
Magnaflow didn't make a duel out complete system for the Expedition so the shop used a single in duel out Magnaflow stainless muffler, stainless Magnaflow tips and fabricated the pipes to make everything fit. The tips exit behind the rear tires at about a 45 deg. angle and are also angled down slightly. It really looks and sounds sweet. I don't have any pictures but the job was done at a local custom exhaust shop, Superior Automotive, here in Portsmouth, Va.
MELMAN
MELMAN
