95 302 headers
95 302 headers
does anyone know if somebody makes headers to bolt up to a stock exhaust system for a 1995 302 on a 2wd f-150. possibly mustang shorty headers?????? the only reason i would like to do this is because my cats went bad and i had to replace them with new downpipes and everything. i later found out that i had a leak in my left side manifold and i would like to use the stock exhaust i just put on thanks for any info
The mustang headers would bolt up to the heads but I doubt if the length would be correct for the f-150.
Check www.summitracing.com The summit headers p/n
SUM-G9035 are only $160.00. Do a search for 302 headers and you'll get a better selection, some of them may not contain the gaskets though.
A gasket are probably all you need for your existing manifold if you don't want to spend the cash for headers, unless one of them has cracked.
