what exhaust
Welcome ! 46 views and no responses.
1) High flow cats do little on stock to mild 4.6s. Your "S" on mufflers implies duals...this setup may lose too much backpressure, but will be loud.
2) Antiquated sound and mild steel rust out.
3) Nice sound, quick rust out, chambered muffler with questionable performance.
You need some higher numbers, I'll be first.
4) A stainless steel, straight-through design muffler.
Give the others some facts: Is this for performance or sound? Is this going to be single or dual exhaust? Do you prefer factory exhaust modification, cat-back, or entire exhaust?
If all you want is loudness, then your "false" muffler is a good idea and so is a straight pipe instead of a muffler. 2 high flow cats instead of the multi-cat setup also increases sound, but is a very expensive way to do it. Shortening the exhaust and turning it down also gives an echo off the ground. The biggest change will be the straight pipe. Another alternative is a cutout. Have a hole cut in the pipe before the muffler and a pipe welded on there with a bolt on cap. Then, you have the choice to cover it back up at will. I don't suggest cable or electric valves though because they don't seal well long term.
