Help me with my dripping wet muff!!!!
OK...I was hoping that would get your attention
I need to replace my factory muffler(with weep hole) because I feel it leaks too much(always black crap all over the driveway right underneath it) I want to replace it with a Magnaflow but don't want to change pipes or anything unless I absolutely have to. It is a 2002 SuperCab longbed as seen in my sig...any ideas or better yet part numbers for a direct replacement?
Thanks,
Jeff
Thanks,
Jeff
you'll have to fab a pipe to get any aftermarket muffler to fit. i say that because the stock muffler is like 36" long while most aftermarket ones are like 24" or less. it doesn't cost that much to get a shop to make you a pipe to go in front or behind the new muffler. you would only need a piece 1' to 1 1/2' long (2 1/2 inches in diameter) good luck.
