can it hurt not to have mufflers
I have a 97 with a 4.6 and I cut the muffler and welded a piece of pipe back where it was. It's pretty dang loud, and it didn't sound good at first, but after about 50 miles, it sounds like a dream, especially when I get on it! I don't think it made any noticeable losses of power (I'm sure it lost some, but not enough to tell). It always turns heads when I step on the throttle at all, but I haven't gotten any static from the cops. I have been pulled over for other things and I have got a litle loud leaving road checks, but they haven't mentioned it. I think it's definitely a mod worth doing, but it's going to annoy your neighbors or anyone who doesn't appreciate a LOUD truck!
ww 2 fighters and bombmers flow with out muflers, nitris oxide was also used-devloped to give extra power.
if your running it wide open, all the time, you will get more power with out muflers, but you will not be drriving at 20,000 ft.
Mulflers regulate sound, and at low speeds help to maintain back pressure. I'm exploering a cat back system for my 04 f-150, 5.4 not sure if i will will go with a dual muflers, or a singel, my truck is a 4wd and the transfer case prevents me from going stright back from the manifolds.
It won't in any way hurt your motor, but will hurt your power. Probably not enough to notice, but in my opinion it will sound like crap! If you want it loud then fine. But being loud isn't everything. Trust me, I like loud too, but a good sounding loud. If your want to have a good sounding loud truck, invest your money in a good high performance muffler. I think removing mufflers completely or installing "glass packs" sounds like crap! And not because it's too loud. You can find a muffler that produces sound just as loud, but sounds 10 times better. Don't be cheap, give your truck what it deserves.
trust me ive never had one person say my truck sounds like crap, and ive had alot of complements on it. Its louder than most chevys and dodges, but sounds very deep and great under hard accell.
Dont listen to this guy that posted above me, straight pipes sound great, and if for some reason you dont like them, you can always go back and have muffler(s) welded in. Too many people pay to have mufflers welded in, then they think theyre too quiet, so they have them cut out and have louder mufflers or straight pipe put in place, and wish that thats what they had done before. I am one of those.
I have some questions. If you go with straight pipes, what dia should be used? Go with the same as stock after the cat or step up the pipe size. Will a larger dia pipe sound differently?
Also is there any truth that an exhaust is louder going straight back out the rear rather than out the sides, like after the rear tires?
Thanks for the clarifications
