Best performance exhaust
#31
new hood
here's where I found the hood
ramairhood.com
Unfortunately, it doesn't come operational, but I spoke with a rep and they said if I want to void the 1yr warranty, I can make it functional very easily. I wanted a functional hood, but I REALLY like the look of this one... I'll just have to void the warranty and make it functional. I'm sure alot of you(like myself) feel that why bother getting a new hood if it isn't functional, I feel the same way.
$595 not painted + $130 shipping + @ $300 for install and painting= $1025 for a damn nice looking hood
ramairhood.com
#32
Magnaflow exhaust sound
Treat, I put a Magnaflow si/do on my '02 5.4l F150; 3" pipe down to 2 1/4", with dual bright 4" SS Magnaflow script baloney sliced tips out the back. Looks great, and the sound is throaty, mellow, and not overpowering. At an idle, you barely notice them, and when you stick your foot in it, they don't have a farty rapping sound, but instead have a deep rich roar :. Cabin noise is really pleasant; I've ridden in some rits with exhaust systems that really drone, and the noise just wears you out on long trips. Not this set up. My mileage hasn't improved, mostly 'cause I stick my foot in it more often now, just to hear the pipes! Good luck in what you choose. If you can, go around and actually listen to a number of different rigs with different exhaust set ups. In the end, it's YOU that you have to please, and no matter how good my setup sounds to me, you might think it stinks.
#33
I just wish I could find a way to make my truck sound like an old 351 modified with straight duals and headers. Well besides installin loud spearkers and a midi board. I dont really care if it is noisy on long trips, thats what I have the Expedition for. this truck is for work and for FUN!!! MTV, PIMP MY RIDE!!!!!!!
#37
#39
Alright heres a different approach for me. I just bought my '00 F-150, 5.4L Triton, I have plans to make it a semi sleeper with a little bling here and there. But I want all performance to be as hidden as possiable untill I am ready to unvail it. One of the blings I'd like is for the exahuast to come out thorugh the body. However I can not find the through the body ring that protects the paint and I dont really feel like Fabing it up unless cost dictates otherwise. Does anybody know of any links to where these might be found? They are not vehicle specific.
I also would like to find a preferabley coated aluminum "for weight as well as to coordinate with the rest of the pipes" headers and mufflers with 3" in and out that are quiet "low rumble at idle & similar on highway" But semi loud under hard accleration. Any one who has experinces that might achieve this best, your opinions would be greatley appreciated.
Also the cats will be non ****ional too, does anyone know how to contend with the 2nd O2 sensor? With out unplugging the Check engine light.
PS Sniffer test are not implemented for vehicle inspection here yet! I will adress that issue when/if the need arises.
#41
Got the Magnaflow 15821 put on my 04 and wow. I could not be more happier. Don't even know it is there at cruising speeds or normal driving. Get on it and you do. Great powerful sound when you get on it. My brother was standing outstide when romped it from a standstill and he said it sounded awesome.
I recommend this system to anyone who doesn't want a LOUD system but does want the performance. It does have a little more pickup now. Just need to finish it off with FIPK. Hoping I got one for xmas.
#42
I posted This before i'm very happy with
www.macperformance.com new exhaust
on my 2004 f150. had gibson on my old truck performance and sound doesn't even compare to new mac stuff check it out.
#43
openclasspro#11
Yes I had considered that too, I am still in debate with myself on it.
treatcg
That sounds exactley like what I am looking for!
However I have not heard or heard of the Mac that 150jack mentioned, but I do like the dual same side exit look on thier cat back systems.
AHHHH To many decisions!!!!! That's great though! I still haven't had any luck finding the rings to go through the body. Maybe if I knew what they were actually called that might help.
treatcg
#44
You can use boat exhaust to go through the body. You can use flex pipe to go from the muffler to the tips. Check these out.
http://www.cpperformance.com/detail.aspx?ID=372
#45
I had thought about that too. But my concern is boats are designed for the exhaust to be cooled by water being pumped through them and wonder if they will get to hot and burn the surrounding paint. I have found these but they are rather expensive hopefully I can find something cheaper somewhere.
http://www.stylinconcepts.com/part.c...&CategoryID=25
