Best performance exhaust
Originally posted by drillsgtjra
Go straight pipes from the cats back....sounds awesome AND is very cheap!
The best advice is the magnoflow like the other gentleman said.
UNless you have a vehicle where you are completely opening it all the time, is light weight with alot of power, i.e. sportscar, then you in no way shape or form should do that...
Its almost just as bad on some vehicles to run duals as that will not create enough and will flow so much that you actually will LOSE power from the too free flowing exhaust...
Hell, some with SUPERCHARGERS, THINK THAT CERTAIN EXHAUST MAY FLOW A BIT TOO MUCH. And those NEED high flow....
Originally posted by slb714
Ok but what does it sound like, is it a nice sound
Took about an hour and a half, working at a leisurely pace, start to finish (removal of old, install of new, turn key and smile)
I'm going to go against the tide here and suggest Flowmaster, simply because I like the sound. They do make their muffers in stainless steel now. 40 Series is a bit loud, 50 Series is nice and mellow but not too quiet. If you like bright stainless steel tips, use Magnaflow tips. They have the nicest looking/most durable tips IMHO.
It really comes down to how you define "best".
i have a friend who has a 4.6 and no muffler.it is not loud.my 5.4 was louder with all the cats in place and a muffler.if you want it to sound good and be able to hear it,run straight pipes from the cats back.you don't take much back pressure off by pullin off the muffler.yeah you would get better performance by replacing the muffler with an aftermarket(i would also suggest a flowmaster) but if you want somethin cheap that sounds good and still performs better than stock just run straights from the cats back.just listen to what some people say on here,they say runnin straight pipes is stupid but then turn right aroun and tell you to get a magnaflow which has a straight through design.that will really not put much back pressure on it so you might as well run straights.i say if you're gonna buy a muffler like that just get a cheap glasspack or somethin and be done with it,they'll perform just the same as a magnaflow they're just not made of stainless steel.i've ran my truck with open manifolds(about 100 feet to pull it in the shop to finish the exhaust)and it still had plenty of torque.runnin what i have now it still pulls the truck just fine.not to mention it will pull anything the suspension will handle.so don't worry about problems if you want to run straights from the cats back it will work fine.
